/ Releases
Ghost 0.10.1
Ghost 0.10.1 is now available on GitHub, npm and Ghost.org. This is a bug fix release, which resolves some gnarly issues with 0.10.0.
  • [Fixed] Uploads & imports on Windows - sorry about that 😳
  • [Fixed] Memory Leak ☔️ - downgrading bookshelf & knex solves this, we're still looking for the exact culprit
  • [Fixed] AMP pages with missing images now fallback gracefully
  • [Fixed] AMP doesn't like old-school HTML attributes such as border
  • [Fixed] Migrations from <0.7 to 0.10.1 will no longer throw an error
  • [Fixed] Cannot find module... config.example error when starting Ghost after upgrading
  • [Fixed] Multiple upgrade notifications - one is enough 😜
  • And a few other bits & pieces...
You can see the full change log for the details of every change included in this release.
In Detail
The most important changes in this release are dependency updates for bug fixes, and dependency downgrades to try to resolve the memory issue. See the note in the How to Upgrade section about reinstalling npm modules.
How to Upgrade
All Ghost(Pro) users are being automatically updated and will be running Ghost 0.10.1 shortly. You're welcome :)
For people running Ghost on their own servers, you can download Ghost 0.10.1 and then check out the upgrade documentation over on our support site.
Note: Due to the dependency changes in this release, it may be necessary to remove the node_modules folder, clear the cache and do a fresh npm install i.e. run rm -rf node_modules && npm cache clear && npm install --production. This is also described in the upgrade troubleshooting guide.
This release was lovingly crafted by Austin Burdine, Aileen Nowak, Hannah Wolfe, Katharina Irrgang and Kevin Ansfield.
Hannah Wolfe
Hannah Wolfe
Hannah is the co-founder and lead developer at Ghost. She spends her days looking after Ghost's developer community, tracking down bugs and ensuring the hosted service is a happy place.
Read More
